M3_Power 636 Report post Posted October 25, 2010 (edited) Dedicated machine setup to run virtual machine GT1. Actual Machine + screen shot: And this is the cable you need to complete the setup: http://cgi.ebay.com/ebaymotors/NEW-Ediabas...omotiveQ5fTools Machine spec: IBM T30 (note one of the RAM slot is faulty, so only one of the slots work). 256MB RAM (to run the GT1 you WILL need to upgrade this to 1G with a single DDR333 PC2700 1G stick - they are about $75 on trademe) 1.8GHz P4 CPU 40G hard drive. 1 battery (lasts about 40 minutes I think) 1 IBM charger NB: I've only ever used this on OBD2 equiped cars, so am not 100% how to set it up for older BMWs that still run the 20 pin plug. Theoratically works on cars between 1998 - 2007. YOU WILL NEED TO PURCHASE AN OBDII Serial cable (this is NOT supplied). Diagnostic head NOT required. To work on cars post 2007 you will need D-CAN cable via USB (but not recommended on a slow machine like this). $380ono The GT1 runs via Serial RS232 port - plug and play - automatic battery and module detection. Serial RS232 cable can be purchased from ebay for about US$40 shipped. Edited October 31, 2010 by M3_Power Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 16, 2011 Hey, is this still available? Quote Share this post Link to post Share on other sites
