burago_2003
Sunscreen Baked into paint
Any thoughts on how I can remove sunscreen handprints baked onto my paint without damaging it?
I've been told to use Polyglaze wax.. turtle wax cutting polish, polishing/rubbing compound and even dishwashing liquid!!
Help!!!
Edited by burago_2003
I suppose dishwashing liquid could work well. As it is quite a tough cleaner I'm fairly sure it strips the wax from your car as well so you'd need to re-wax it after.
Before that I'd try meths or WD-40 as well.
My 2c.
You could always try desolve it, it's a citrus based solvent so should be pretty easy on the paintwork.
I've used it on anything from removing oil off leather lounge suite, tar off paintwork, removing stickers/decals - i would think it would be ideal for what you need it for.
Yeah heard bout the dishwashing liquid and actually did try it but didnt work, and i also tried WD-40/CRC.. nothing as well!
Cheers chaps.. Polyglaze worked a treat and man the difference that had on bringing my paint back to life.. WOAH!
