nzhaystack 0 Report post Posted January 7, 2011 Hey Everyone, Currently got a getrag box in my car at the moment and need to know if this one would bolt up to bell housing. http://www.trademe.co.nz/Trade-Me-Motors/C...n-345388986.htm Car info: e30 320i 1984 5 speed getrag m20 manual Cheers Mitch Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted January 7, 2011 If it is "true to label" then yes it will. Some E30's came with these, That said - I have only ever had/seen Getrags in them You say "bolt up to bell housing" - the bell housing is part of the box Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted January 7, 2011 no, the selector is diferent in your car and you will need to confirm driveshaft length. best to replace with like for like, otherwise there will be a little mucking around Quote Share this post Link to post Share on other sites
nzhaystack 0 Report post Posted January 7, 2011 no, the selector is diferent in your car and you will need to confirm driveshaft length. best to replace with like for like, otherwise there will be a little mucking around Good point Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted January 8, 2011 have had a chat to that seller about the box. an he got it to go in behind his m20b23 but as said selector was a issue an his drive shaft was too short. by only the smallest of margins. Quote Share this post Link to post Share on other sites
richard 384 Report post Posted January 9, 2011 Yes it will fit ,( the shifter is a problem if you keep the center console) I have both and can inter-change them without any issuses . running the ZF in my car because it has no breath on top to leak out of when racing on the track . Quote Share this post Link to post Share on other sites
