Ugan
E36 325i man
Hi All
I recently purchased a 1995 e36 325i man nz new.
Car has high milage roughly 275000km on the clock, will pick up this weekend.
It is a stock standard example no mods and i wil keep it this way bar a set of new rims and tyres, gear lever has a slight play and engine sounds fine bar a sight rattle on cold startup, all acceptable bearing in mind year \milage.
Can anyone provide me info on the service shedule, i will complete the standard oil, plug and airfilter change?
Any other preventative maintainance that should be done?
Should i get the car plugged into a computer to check any existing fault codes etc?
Thanks/
Whoops jut read the sticky, thats given me smething to go by...Cheers.
Edited by Ugan
