RustyItalian 11 Report post Posted March 16, 2011 Autronic SM2 ECU - Brand new never used. Comes with 1.93 Chip, namely autotune, flat shift, launch control, boost control, antilag and traction control. Above the normal SM2 spec it is installed with a dual dwell board to allow the use of coils without on-board dwell (I was planning the Toyota coil-over-spark units from the Altezza). Also comes with the Autronic boost control valve allowing full boost control by the ECU. What I have done: -Aluminium bracket designed to fit the Toyota Celica stock ECU location allowing the stock harness to plug in directly. Obviously for a BMW you would need to cut these plugs off take a different approach. The ECU (with different plugs) could run any engine you care to mention really. The dwell board can run a pair of ignitors (or 4) allowing a 4 cylinder to run in wasted spark mode (no dizzy required). The dwell time is adjustable depending on what ignitor you are running. Different chips could be installed and the dwell board removed as required by someone like Edgell. I’m not continuing with this project as I’ve simply run out of time (house, wife, baby etc etc). NZ$2500 for the Autronic and all documentation. NZ$500 for four brand new P/N 90919-02227 Toyota Altezza coils (current TNZ price $165+gst each). Local companies experienced with the Autronic are Edgell's and Road, Race & Rally in Penrose. PM me for more info and photos Quote Share this post Link to post Share on other sites
RustyItalian 11 Report post Posted March 18, 2011 Now on trademe. Quote Share this post Link to post Share on other sites
RustyItalian 11 Report post Posted January 28, 2012 This unit is still for sale. A very capable ECU. Would now accept $2000 for the ECU and parts. The Toyota ignitors I'll still sell seperate. Quote Share this post Link to post Share on other sites
rugbymax 0 Report post Posted April 17, 2012 This unit is still for sale. A very capable ECU. Would now accept $2000 for the ECU and parts. The Toyota ignitors I'll still sell seperate. hi!still have the ecu for sale?do u think is ok fot toyota st185?thanks Quote Share this post Link to post Share on other sites
