SRBMW 6 Report post Posted March 23, 2011 Complete rear end from e36 m3 evo 3.2. Comes with large case 210mm lsd shafts hubs large brakes and cradle, will bolt into all the e36- great rear for a serious e36 3.15 or 3.25 ratio from memory will have to check $1550 Steering rack from e36 m3 evo same turns as normal e36 but quicker ratio $350 Lower control arms to suit evo good for e30 5 stud conversion more castor than normal e36 and m3 $350 Darren 0211645663 Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted March 30, 2011 (edited) Complete rear end from e36 m3 evo 3.2. Comes with large case 210mm lsd shafts hubs large brakes and cradle, will bolt into all the e36- great rear for a serious e36 3.15 or 3.25 ratio from memory will have to check $1550 Steering rack from e36 m3 evo same turns as normal e36 but quicker ratio $350 Lower control arms to suit evo good for e30 5 stud conversion more castor than normal e36 and m3 $350 Darren 0211645663 Edited March 30, 2011 by Jono51 Quote Share this post Link to post Share on other sites
