BmwolfJR
need a little help
i need some help with the m20b25
i need to now how the alternator works and how to test one in the car
thanks
thanks
In the car?
Key on - ign light should come on & go off when running. check voltage at battery - should be around 14v engine running
Alt has two wires - a main battery supply & the w/l wire above. If the ign light doesn't come on with key on, earth the blue wire at the alt - light on = faulty alt, light still not on = wiring/bulb - w/light circuit.
Make sure the alt battery supply is infact alive.
