thirdkide30 0 Report post Posted May 18, 2011 (edited) My fuel pump seems to not be running. I have changed the ignition switch and seems that its not that. Just wondering where can i look next? Edited May 18, 2011 by thirdkide30 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 18, 2011 My fuel pump seems to not be running. I have changed the ignition switch and seems that its not that. Just wondering where can i look next? You changed the most unlikely thing first. Check the fuel pump relay - is it switching power to green/purple wire while cranking? If so - check power is getting to the fuel pump = if it has power & earth & is not working - faulty pump Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted May 18, 2011 Also check the connection at the fuel pump. I've had a few now where I've had to squeeze the plugs to get good contact again, they work lose and loose contact. Quote Share this post Link to post Share on other sites
thirdkide30 0 Report post Posted May 19, 2011 Damn rains been keeping me away from the car but just noticed the fuel relay is good. Still clicks and did a trigger test on it. But on the black relay box the relays look like this O O OO That relay thats coloured red was the one that was broken. Just wondering what that relay is for? Will try clean the contacts tomorrow. Quote Share this post Link to post Share on other sites
