thirdkide30
Fuel pump not going
My fuel pump seems to not be running. I have changed the ignition switch and seems that its not that.
Just wondering where can i look next?
Edited by thirdkide30
You changed the most unlikely thing first.
Check the fuel pump relay - is it switching power to green/purple wire while cranking?
If so - check power is getting to the fuel pump = if it has power & earth & is not working - faulty pump
Also check the connection at the fuel pump. I've had a few now where I've had to squeeze the plugs to get good contact again, they work lose and loose contact.
Damn rains been keeping me away from the car but just noticed the fuel relay is good. Still clicks and did a trigger test on it. But on the black relay box the relays look like this
O
O OO
That relay thats coloured red was the one that was broken. Just wondering what that relay is for? Will try clean the contacts tomorrow.
