Vert
Tappet / lifter noise ?
Can my m20b25 e30 tappet / lifter noise be adjusted ?
Sure can - need a piece of wire or similar to rotate the adjuster mechanism to set clearance.
Sweet man no of anyone that might do it ? Or is it easy enough to do it yourself ?
Pretty straight forward. Anyone with some mechanical knowledge can do. If you are unsure - take it to a garage.
