montsta56
Off set
depends on size & width,
but if it were a 17x8" et13 for example you should be fine.
et 20 is standard,even with 8x17,does 13 put the wheel further inboard or futher out,i can never remember.....
is the e significant,ie ET20 = 20mm offset to the exterior of the wheel??or do you assume that offsets are negative ie towards the outside of the wheel....i know threes are 35 mm what are the offsets of other cars say commodores,falcons,nissan skylines.......
