Gunner 0 Report post Posted July 3, 2011 Just want to confirm the lengths that I should be buying to replace the interior bulbs. I read that people are using between 36mm to 41mm leds. Cheers Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted July 3, 2011 Cant recall exactly but I would say they will be 36 ish (ish because they can vary between manufacturer)Take a cover off & check I have 36mm LED's if you need. PM me if you want Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted July 3, 2011 Pretty sure they are 36mm. I haven't tried using LED myself in interior, but the fade-in/out lighting may not work properly. Quote Share this post Link to post Share on other sites
Gunner 0 Report post Posted July 3, 2011 cool thanks. i'll let you know. just toying with the idea of changing to led. Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted July 3, 2011 (edited) SpikeyLemon said: Pretty sure they are 36mm. I haven't tried using LED myself in interior, but the fade-in/out lighting may not work properly. I have LED's in all my interior lighting and the fade works fine. Very happy with the mod.Only trick is to check the way you install LED blubs have to be a certain direction. If they don't work they flick them around. Another point would be that I had two different sizes throughout the car. It might pay to pull a few out to confirm what you need & how many before you order. Edited July 3, 2011 by M5V8 Quote Share this post Link to post Share on other sites
