[email protected] 0 Report post Posted July 10, 2011 Hi, I've replaced my coolant and while the engine temp seems stable, the heater only runs cold. I fully drained my coolant system from the rad and the block (with heater controls on hot), then flushed it through and replaced with as much coolant as will go in (about 7.5L when Bentley tells me the capacity is around 10.5L). I've bled it cold and then at running temp but seemingly can't get the air out of the heater. The line running to the heater from the block is hot but the return to radiator is cold. The heater solenoids seem to be the highest point in the cooling system but doesn't have a bleed valve I can find. This must be an issue faced on a regular basis so am I just missing something obvious? Any suggestions? Many thanks in advance Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted July 10, 2011 Never mind, got it sorted Quote Share this post Link to post Share on other sites
OP6 27 Report post Posted July 11, 2011 Share Quote Share this post Link to post Share on other sites
Huttey 0 Report post Posted July 11, 2011 Why do people share their problems but never share their solutions, got me puzzled as isn't this what a forum is all about so can learn from other member's experiences. Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted July 11, 2011 +1 should be a new forum rule Quote Share this post Link to post Share on other sites
