Guest Andrew
Good shock buy for e36 boys
Guest Andrew
Howdee all,
We have for you today,
4 Adjustable Tokico shocks for E36, one off deal to bimmersport members at $900 inc GST.
Get them now and save $$$ on shocks.
Contact me for more info, or if you want to order call 027-240-1077.
Andrew
Guest max
Awesome shocks huge in America, check out the website www.tokico.co.nz :D
Guest max
they are 5 point adjustable at the top of each shock it adjusts bump and rebound at the same time not height adjustment but you can run lowered springs on them, basically you can adjust the shock to suit different road surfaces as well as your driving style, in America they are used by people who want to retain a good ride and then if they want to do a track day or higher speed driving you simply adjust the top with key provided to suit your needs on the day. :D
