sti-ted
wtb e30 bits
hey guys,
im after a few bits for my e30 pfl.
getrag 260 clutch fork.
e34 accelerator cable.
plastic rails that the sunroof attaches to (both sides).
the piece at the end of the gearbox that the gear selector rod goes through (hope this makes sence) for older style 260 see pic :huh:
cheers
frederic
Posted Image
Edited by frederic
I ended up getting the parts you have highlighted new from BMW for around $100. That was for the dowel pin, the tension bush, the washers and the bracket. Well worth buying it new in my opinion as you'll end up with a solid shifter. It's probably worth replacing the bush (number 2 on the diagram) too. The circlip 13 can be salvaged off an auto box as well. All those parts were ex-Auckland and took 3 days to receive.
