sexy beast
E34 CENTRAL LOCKING
Hi All,
I know this problem exists with the E34's. My previous E34 had this problem come up once and i accidently had it solved when i recharged the car battery...it started working again.
Now, with my current E34, thought it was the same issue. (by the way the car battery drains away if i dont use the car for a week at least. Read somewhere that its to do with the heat locks-for freeing up the locks in cold season where locks may get cold and jammed - but thats a problem to solve another day).
I have recharged battery in the weekend but still no central locking. when i put the key in the drivers door and turn it to unlock, all doors unlock then bounce back to lock position apart from the drivers door which is in the open mode all the time. I tried unlocking trunk with key but same thing, unlocks then bounces back to lock position.
Also read that it could be to do with the fuse under rear seat or the wires under trunk hinge area or the lug pins been rusted and old in the right panel next to speaker in the drivers leg area where the central locking computer sits apparently.
Any of you good people had same issues...many thanks for reading my post and appreciate all the help and advise.
