lakay01 0 Report post Posted September 22, 2011 Need Help! From the DIY on the web a lot of the available material are for LHD. When I opened up my ECU ther is no ACC trigger wire color coded red and white with yellow/gold dots. Have seen posts that the actual trigger wire is color coded green? Could someone verify what is the correct wire? Maybe a schematic for an e46 318i 1999? Also, I have seen installation for the remote trigger via the footwell lights, but I dont have any on the car. Any suggestions for an alternative wiring for the remote? Schematic, procedure...... Thanks a lot! Quote Share this post Link to post Share on other sites
