scott_e30 8 Report post Posted October 30, 2011 Often the remote unlock button wont work so I have to put the key in the door to unlock the car, although sometimes when i do this only the drivers door opens and the others remain locked? Sometimes it take 15mins and multiple goes until finally the other doors will unlock. Its a 1999 E46 Any help would be appreciated Thanks Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted October 30, 2011 (edited) Is it a jap import? Try pointing the key at the red thing (sensor) attached to the bottom of the rear view mirror when you push the button, afaik jap imports use an inferior infra-red system. Have the same problem with my old man's e46 Edit: That's just for the remote locking problem, I don't think he has any problems with opening all the doors with the key, so can't help there sorry Edited October 30, 2011 by sascha Quote Share this post Link to post Share on other sites
Yankus 0 Report post Posted October 30, 2011 could also be a faulty drivers door lock motor, faulty key or faulty body control module.....have Botany Motor Worx check it out. Quote Share this post Link to post Share on other sites
scott_e30 8 Report post Posted October 31, 2011 Is it a jap import? Try pointing the key at the red thing (sensor) attached to the bottom of the rear view mirror when you push the button, afaik jap imports use an inferior infra-red system. Have the same problem with my old man's e46 Edit: That's just for the remote locking problem, I don't think he has any problems with opening all the doors with the key, so can't help there sorry Tried that, no joy. Also it's NZ new. Thanks Quote Share this post Link to post Share on other sites
