M3_Power 636 Report post Posted November 9, 2011 Purchased this from Country Theme in Newmarket about 6 years ago. In good used condition apart from two long scratches (about 30cm) in the top glass (visible if you look for it, but given it is a glass top it doesn't really pop out unless you look for it). On wheels that can be locked to stop it moving. Quite a heavy table as both layers are glass and the frame is metal (steel??). Very sturdy and chic . Will provide dimensions later on. http://www.trademe.co.nz/Browse/Listing.aspx?id=421540290 Quote Share this post Link to post Share on other sites
