cookies
E36 Sunroof Problems
Hi Guys,
Having some problems with the electric sunroof in my 318is. Just today i put it fully open on slide and when i tried to close it the forward button did nothing, no motor noise or anything. After reading about i used an allan key to put it forward a couple cms and then suddenly the button worked again and let it close and open like normal. I have noticed it feels slightly loose when you push on it from the inside and the tilt seems to be slightly slower than normal. It seems to be working fine now back and forward but im sure its probably only a matter of time before the problem re-occurs.
Just wanting to know whether anyone on the forum could help a new member out with some knowledge on the fault. Is there a particular part that may need replacing, or possibly has something come loose or in need of adjustment?
Thanks for the help,
Jordan
With the roof open, check the tracks to make sure it's clear of any obstacles, dirt, fluff, etc... Wipe clean throughout reapply grease if dry and test.
