Repent
E30 REAR shocks & springs
Guest Andrew
Rear only. Used.
Adjustable Koni shocks & Jamex lowering springs (50mm drop).
$195.
where is the adjuster
Not sure how old they are, I bought them off trademe but have decided not to lower my car as I have an expensive repair bill coming up and need the money. The guy I bought them off said he had them tested at Stocks and they were in good condition.
Regarding the adjustment, I was told you have to compress the shock and use a spanner to turn it clockwise (harder) or anitclockwise (softer).
I'm pretty sure the "Reds" aren't adjustable, and they don't look like E30 rear shocks!
Well I must have been mislead when I bought them. I was advised these came off an E30. I'll see if I can get someone to check these shocks to confirm they fit E30s and if they are adjustable or not.
