Surge
Parting up 84 320i - Lots of stuff.
Hey all,
Parting up the parts car...
Nearly all items available.
4 good doors.
Glass (minus the front windscreen)
Most interior seals.
Interior pieces, all in good condition.
Tan carpet + Tan Cards + Tan rear seats - can supply front seats at no extra cost as they are fairly rooted (just needs a recover)
Heater switches, controls etc.. All available.
Seatbelts.
Boot carpet.
Some (read SOME) engine bits available, Gearbox is taken for own personal use.... :ph34r:
All steering/suspension componants not available - using to fix damaged suspension/steering on my other 320i.
PM me with any request, I'd like to offer bits to you folk before going to nasty trademe.
Thanks,
James
Check your PM's. Negative on the pedal box, Using it for my swap - sorry.
Is my head in the clouds if I ask....... spotties? :huh:
Unfortunately those were taken out when the car was crashed - I've got mangled up bits of them.... :P
I do however have 1x right hand side set of pre FL headlights.
Edited by Surge
theres a set of spotties on trade me at the moment, pre fl as well. only at 10 buck at the moment
hi do you still have the rear lights ? they need to be in a1 condition tho :rolleyes:
Neg on the rear lights, one's got a big chip in it and the other I'm using to fix the painted black ones on the project car. Sorry about that.
I just need one of the spotlight lense covers,you still got one of those in good nick?
Sorry, all cracked (in bits)
Fuel pump for $100 (ono) - wreckers are after $180
do you know if the engine wiring harness is the same as an 83 323i? If so I might be interested. Actually need the complete car wiring harness, but need the engine first. LMK shipping is only to the US.
Hi Deano, Will need to check on - cars located in Avonhead, I'm in Spreydon.
CourtM3, Not sure on that - maybe someone else on these forums could help?
The engine in my 1986 320i physically seems identical, right down to a fuel relay from an E28 5-series, I'm thinking the engine is a 1985 one.. or the same.
- Will check on condition of car wiring harness.
