Deano
E21 323i
Hi..I need 2 front struts and they need to be the larger insert tube diameter with the thread on the inside of the tube as opposed to the outside on 320/6 and early 323i. Anyone wrecking on would be a help. Condition of springs and inserts no concern.
Hi Deano,
Are these 'cross compatible' with any E30 struts? or E21 only. Assume the size you're after is 51mm?
O yeah... your car isn't green is it?
Edited by Surge
