krish
EOI: E46 6 Cylinder Cold Air Box
Hi Guys,
I am working on a design for an Aluminium Cold Air Box for the E46 6 Cylinders Vehicles
Will be a fully inclosed unit, you will use the pod filter of your choice
This will be allow you to keep as much enginer heat away as possible and will sit behind the head light
I am also looking into linking it up with the factory kidney grills intake as well
It will be constructed from 2mm Aluminium and will be CNC Laser Cut with Pressed Insert to screw lid down
Will post pics once I have made a prototype
Just wanted to know if people would be keen them
Thanks
Krish
