deshanv
Wheel Offset for E46 M3
Hi Guys,
I need some help understand and choosing what is the perfect offset to go for on wheels for my M3.
The rim is a Forged Concave 3 piece rim in 19"
The fronts will be 19x8.5 and Rears will be 19x10
the lip will be 4-5 inches.
I need to know what offset will fit perfect on my E46 M3.
If I have mentioned anything that is not right please let me know as well.
I am currently getting a company overseas to custom make the rims for me. They just need specs to give me a quote so need your guys help.
Thanks
Picture of the rim
About +35 in the front and +25 in the rear would be fine, are you looking for that 'flush' look? if so then a bit less in the front and rear offset.
Edited by AJ_D
Thanks mate,
I am after for an aggressive look, thanks
Wait until Jono sees this to confirm but that should be about right.
Posted Image
That is running 19x10.5" with ET22 on all corners
You could go as low as ET10 on a 8.5 in the front and ET20 on a 10"
It all varies on how aggressive you want to be and what tyres you are going to run?
Edited by DrphTa
