JesseRaymond
e30 1986
What are you trying to do?
They have a stock brake booster. Unless you are heavily modifying the engine or racing the car I wouldn't see a need to change it.
if you are having braking problems either get it checked out by a professional or replace pads/rotors and give it a fluid bleed and make sure there is no air in the system.
Ok thanks for your help
