e30morgs
Lock bolt Key
After the use of a lock nut key, pretty sure it is the same one as the one pictured, just need to borrow the bit so I can replace with the stock bolts, any help would be much appreciated. Also the nature of the wheels means that banging on a socket will not work, Cheers
Cold Chisel :D
