JaseNZ 53 Report post Posted August 13, 2012 So for the past year I have been experiencing flickering Xenons and I have not been able to track down what is causing it. It is both of them not just one so this suggests a short somewhere ??. Its also very very random , It will happen for a few days and then things could be fine for a few months then start doing it again. I don't want to start replacing expensive stuff if its not the contributing factor. I have been around all the earth points (I know of) and secured them. Checked all wiring I know of and that seems to be all ok ??. No errors showing up on a scan. Possible loose solder joint in the lcm ?? , Any ideas anybody ?? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted August 15, 2012 So for the past year I have been experiencing flickering Xenons and I have not been able to track down what is causing it. It is both of them not just one so this suggests a short somewhere ??. Its also very very random , It will happen for a few days and then things could be fine for a few months then start doing it again. I don't want to start replacing expensive stuff if its not the contributing factor. I have been around all the earth points (I know of) and secured them. Checked all wiring I know of and that seems to be all ok ??. No errors showing up on a scan. Possible loose solder joint in the lcm ?? , Any ideas anybody ?? Normally the ballast which is at fault. Google "flickering xenon" for lots of info Otherwise, it is simple End of Life for the bulbs. Replace the bulbs. Read this: http://en.wikipedia.org/wiki/High-intensit...amp#End_of_life Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted August 16, 2012 Cheers for that, Have had a good look around, alot of it though is all over the place and suggests all sorts of things so is hard to narrow down the cause, May be a case of swapping things out with the help of the local wrecker until I find the problem then replace that part with new. What would the price of a new set of bulbs be anybody know off hand ??. Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted August 18, 2012 (edited) Did you buy a DC ballast rather than a AC one? those are unstable and cause flicker, Or your grounding which was a problem i had with mine. Edited August 18, 2012 by aw-krazy Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted August 19, 2012 Cheers for that, Have had a good look around, alot of it though is all over the place and suggests all sorts of things so is hard to narrow down the cause, May be a case of swapping things out with the help of the local wrecker until I find the problem then replace that part with new. What would the price of a new set of bulbs be anybody know off hand ??. do you know the type of lamp you have? Quote Share this post Link to post Share on other sites
Smac01 12 Report post Posted August 19, 2012 I'm sure I've got a pair of bulbs lying around. I bought about 5 pairs off eBay earlier this year. Not OEM but might help you diagnose. PM me - free (you pay postage) Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted August 19, 2012 Cheers for the Reply's guys, going to hold off on the bulbs for the moment , If just one was flickering then I would have presumed an on the way out bulb but both of them flickering together at the same time suggests something else going on somewhere. Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted August 20, 2012 Cheers for the Reply's guys, going to hold off on the bulbs for the moment , If just one was flickering then I would have presumed an on the way out bulb but both of them flickering together at the same time suggests something else going on somewhere. I would go buy a new ballast, make sure it is an AC ballast as that will delivery a continuous current as opposed to the DC. Make sure you get the right wattage. Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted August 29, 2012 Ok so have fixed this problem after getting my arse into gear and really checking things out. Flickering was caused by a short on the rear right hand side tail light. Problem solved Quote Share this post Link to post Share on other sites
