Bent
Trailer LED Lights
Does anyone know why new LED trailer lights would stop flashing the indicator when the brake is applied. These are american style lights (ie red coloured. brake/lights and indicator in one unit) There is one double plug - brown splits off to two further plugs, while there are three earth wires. All attached exactly as for the previous bulb light but now stop the indicator flashing when the brake goes on.
Thanks
Likely you have wired them incorrectly, or it is a US-function for US lamps (did you get them from the US?)
wired wrong, had the same problem, found earth was white wire.
