IIIRII
96 318Ti Rolling Shell Suit Race Car Build
I have a 318tiCompact pretty much completely stripped
It has new trailing arm bushes, new rear wheel bearing, ally subframe bushes,
The car is at the point where its about to have the cage done and all the welding finished.
At this stage it has been turreted in the rear and has a cromoly frame for holding a ma 70 supra diff centre, on spuds tacked into position.
You could just weld it all in and make some flange adaptors and job done.
Rego on hold, it was an auto.
It would be real seay to convert it back to a factory diff centre just by putting another rear subframe beam into it.
Its rolling / I have all the glass and doors etc: to put it back together, I did cut some of the wiring loom to get it out but its pretty much intact (i wasnt going to use it as its overkill)
It was a complete driveable car, I still have all the bits needed to make it a road legal race car etc:
Im wanting $800 for thje rolling shell, without the diff centre.
All part to go with it I have collected are negotiable to the person who buys it
Open ma70 diff centre 4.55 or 5.3 ratio
Including screw in studs 50mm L to convert the hubs to stud
Adjustable front strut tops
Aftermarket wiring loom
Springs to suit the shocks (shocks are not for sale)
Adjustable Pedal box
Some other bits ive probably forgotten about
PM Me a contact number
Dont ask for any individual parts as the person who buys the shell has first option so that needs to go first.
Cars in Franklin Area
Ak
Edited by IIIRII
