M3_Power
FS - Genuine E46 M3 front bumper (for pre 2002)
For cars with the aluminium front carrier (not the carbon kevlar type).
In brand new never mounted condition.
Painted Silver Grey.
Was used for moulding a project bumper, so the paint isn't in perfect condition but not too bad.
The left hand foglight carrier was carefully cut for the mould, but has been glued back on - I would recommend maybe a bead of plastic epoxy on the back of it or some minor plastic welding just to be 100% certain it won't fall off. (once the foglight is on you won't even see the bracket)
Otherwise in brand new condition.
$450 take it away (no licence plate holes ever drilled)
Posted Image
the cut off and reglued bracket:
Posted Image
Edited by M3_Power
Will this only work on m3?
look on e46fanatics - it can be done, but not a bolt on job as the M3 bumper is slightly wider. If you force it to conform it'll look all wonky under the headlights - if you fit it in M3 width the bumper will stick out by about 15mm each side I believe.
http://forum.e46fanatics.com/showthread.php?t=426625
Edited by M3_Power
