Deano 1 Report post Posted January 16, 2013 (edited) Ratio 3.45:1 probably from early M635 or M535 E12 Can freight cheaply around NZ Edited April 25, 2013 by Deano Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted January 18, 2013 http://www.trademe.co.nz/Browse/Listing.aspx?id=553415281 021 230 4284 Gotta go make an offer, would be awesome diff for race car... Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted January 22, 2013 Ratio is 3.45:1 Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted February 16, 2013 Still here. Have two types of output flanges with it. One set marries up to E21 half shafts and the other set is the standard larger diameter flanges for the E12 m535 Quote Share this post Link to post Share on other sites
exige92 0 Report post Posted February 17, 2013 how easy does it fit to an e21. What else has to be changed? Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted February 17, 2013 It is possible but the subframe requires modification. This diff is the medium case. To fit the E21 you will have to shave 2.5mm of the diff flanges and half shafts. The correct diff required is the small case sideloader and fits between the half shafts without mods. Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted March 17, 2013 (edited) This diff is still for sale and $400 is the price Diff is in Muritai, Wellington from Thursday so North Island Freight will be about $25 to a depot near you. Edited March 17, 2013 by Deano Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted April 25, 2013 Still have the LSD diff $400 can freight cheaply anywhere in NZ Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 26, 2013 So it's the 188mm ring gear? Any idea if the centre can be used in later diffs? Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted April 26, 2013 So it's the 188mm ring gear? Any idea if the centre can be used in later diffs?No idea sorry Quote Share this post Link to post Share on other sites
