Deano
E9, E12 and early E24 LSD diff $400
Ratio 3.45:1 probably from early M635 or M535 E12
Can freight cheaply around NZ
Edited by Deano
Still here. Have two types of output flanges with it. One set marries up to E21 half shafts and the other set is the standard larger diameter flanges for the E12 m535
It is possible but the subframe requires modification. This diff is the medium case. To fit the E21 you will have to shave 2.5mm of the diff flanges and half shafts. The correct diff required is the small case sideloader and fits between the half shafts without mods.
This diff is still for sale and $400 is the price
Diff is in Muritai, Wellington from Thursday so North Island Freight will be about $25 to a depot near you.
Edited by Deano
Still have the LSD diff $400 can freight cheaply anywhere in NZ
  Ahmedsinc said:
So it's the 188mm ring gear? Any idea if the centre can be used in later diffs?
No idea sorry
