Cab
E30 325i Tune-up / Power Upgrade
Hey guys,
Im wanting to get my manual e30 325i cabriolet tuned up/chipped. It runs fine at the moment but im just after a bit more power.
I've heard Hi Velocity is the place to go.
Ideally I want to spend around $1000 give and take.
Has anyone else been there/got any recommendations on experienced people in the know?
Thanks
Edited by kalamarisoup
Gavins the man..had 2 e30s done with great results including improved fuel ecocomy
What work did you get done? What sort of gains? Cheers
ECU remap.....gained about 7rwkw from memory...cant remember torque numbers but a decent increase.
Definitely a very marked improvement in driving performance
Waste of time.... Have one in my ecu doesn't do much. E30s don't even have a speed cut lol
A decent chip will give you gains.... if your not worried about fuel consumption also put in a 3 bar fuel pressure regulator, bore your throttle body to 64mm, add a decent exhaust header and richen up your air flow meter.
