kim0663
e36 328i motorsport $4k ono
http://www.trademe.co.nz/Browse/Listing.aspx?id=578709167
Pics are on trade me. I will upload some pics soon, otherwise tardme shall be thy friend.
Comes with
- 18" Genuine bmw motorsport wheels
- Led tail light (Comes with the original ones too)
- Tinted windows
Recent work includes (all parts used were genuine from bmw or oem)
- New camshaft position sensor
- Vanos seals and timing chain tensioner
- Valve cover seals
- New spark plugs
- New exhaust mount
- New tie rod ends, inner and outer on both sides
- New drive belt idler and tensioner pulleys
- New thermostat with alloy housing
- New water pump
- New rear wheel bearings
- Rebuilt driveshaft joints
- New driveshaft centre hanger bearing
- New heater valve
Before this, the car was fully (might I also add regularly) serviced with
- Oil and filter
- Transmission fluid change
- Diff oil change
- Cooling system flush
Spent way too much money on this car for the sake of seeing it running its 100%. It IS running a 100% and now that that's done, I can start spending on my other cars.
Good base for someone to keep for the future and cherish, quick daily driver, or someone to sack it down and start cruising without the car sounding like a POS.
Drives awesome and I would dare say first genuine buyer to test drive would probably buy it on the spot. This car drives like how a real 328i should drive.
021 112 4597
Edited by Y.J.Kim
