M5V8
occasional stall - solved
issue - occasional stall when coasting upto stop with clutch disengaged when engine is warm (long drives only)
scan - showed O2 sensor faults
replaced - MAF sensors
Test - well it didn't do it on the wknd. last time i did the same drive it stalled twice. I tried to coast up to every red light.
result.
awesome.
Thanks for everyones's input. I love this forum.
However the much touted MAF test show only 90 odd something flow rate. Pretty much like before. I expected a higher reading. Is this due to atmo correction or is there another factor at play with these tests?
I'm planning on changing the pre-cat 02 sensors & fuel filter also in the near future and getting a scan tool to reset and then check the warning codes again.
Anyone have an idea what else I might have missed?
*note: there's no real performance problem of note, car pulls hard. New spark plugs and always 98 octane fuel.*
Edited by M5V8
