M5V8 337 Report post Posted April 14, 2013 (edited) issue - occasional stall when coasting upto stop with clutch disengaged when engine is warm (long drives only) scan - showed O2 sensor faults replaced - MAF sensors Test - well it didn't do it on the wknd. last time i did the same drive it stalled twice. I tried to coast up to every red light. result. awesome. Thanks for everyones's input. I love this forum. However the much touted MAF test show only 90 odd something flow rate. Pretty much like before. I expected a higher reading. Is this due to atmo correction or is there another factor at play with these tests? I'm planning on changing the pre-cat 02 sensors & fuel filter also in the near future and getting a scan tool to reset and then check the warning codes again. Anyone have an idea what else I might have missed? *note: there's no real performance problem of note, car pulls hard. New spark plugs and always 98 octane fuel.* Edited April 16, 2013 by M5V8 Quote Share this post Link to post Share on other sites
