topcat 11 Report post Posted May 15, 2013 have a m52 2.8 on tade me at present that needs a home, http://www.trademe.co.nz/Browse/Listing.aspx?id=591725476 200k's,NZ new. e34 sump and mounts fitted. m50b25 inlet mani. looking for $1250. also have an early e36 non ews loom/ecu/airflow etc that would complete the package $150 Quote Share this post Link to post Share on other sites
slowe30 0 Report post Posted May 22, 2013 is the loom/ecu that you have for a vanos or non vanos engine. and I've got my fingers crossed that you'll sell that all separately?? looking for a setup that'll run my m52b28 better than the current ecu (from a non vanos something, not to sure what tho) Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted May 22, 2013 is the loom/ecu that you have for a vanos or non vanos engine. and I've got my fingers crossed that you'll sell that all separately?? looking for a setup that'll run my m52b28 better than the current ecu (from a non vanos something, not to sure what tho) yes,the loom is a single vanos type. but not keen to seperate at the moment,will have a hunt around,should have another loom and check for vanos etc Quote Share this post Link to post Share on other sites
