02e46m-sport 1 Report post Posted May 22, 2013 hey guys i need two 10mm spacers, if ya have some for me pm or txt me on 0210 2480 306 cheers Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted May 22, 2013 hey guys i need two 10mm spacers, if ya have some for me pm or txt me on 0210 2480 306 cheers 2c. 10mm is a nasty size as most won't be hub-centric, not enough material. IIRC the turner 10mm spacers come with fancy blue anodized hub extenders to locate the wheel. 12mm are pretty common, turner, rouge, H&R. I run 15mm Rouge spacers and are v.good quality. Quote Share this post Link to post Share on other sites
02e46m-sport 1 Report post Posted May 22, 2013 2c. 10mm is a nasty size as most won't be hub-centric, not enough material. IIRC the turner 10mm spacers come with fancy blue anodized hub extenders to locate the wheel. 12mm are pretty common, turner, rouge, H&R. I run 15mm Rouge spacers and are v.good quality. cheers bro 15mm it is then more width cant hurt Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted May 22, 2013 cheers bro 15mm it is then more width cant hurt That's what I thought Rouge do some 10mm spacers, have a look at the pic, the big chamfer bit needs to fit your wheels, if not, your screwed, so just go wide Quote Share this post Link to post Share on other sites
