albert72
WTB E30 WIPER RELAY
anyone got a good wiper relay for sale. My wiper is driving me nuts <_<
Edited by Tom325
Thanks
Will this fix my window wiper being weird on low speed, It hardly drags unless you hold down on the wiper control but med and high are sweet
you probably just need to clean and re-grease the insides of the wiper motor.
It's pretty easy, my dad could almost do it without my help.
Sorry to sound like a complete idiot! but where abouts is the wiper motor access? through those grilles near windshield?
on an E28 yes. On a E30, Probably. drivers side grill most likely.
Thanks bro! will try this weekend :)
I thought about the motor but I'm guessing since the wiper are working fine on speed 1 & 2 then it must be something else, like the relay
what's the problem? if it's just generally getting stuck half way or not working quite as it should on slow speeds its probably the motor and needs a clean and re-grease.
If a certain speed is not working at all. e.g. intermittent isn't doing anything it's most likely the relay. E30s and E28s use the same relays so they are very easy to find.
Intermittent literally works intermittently. sometimes it works and sometimes it just keeps on going like on speed 1. When you turn it off from intermittent or from any speed, it just stops halfway. I'm thinking either the relay or motor maybe the culprit but want to start with the relay (much easier).
One more thing, I hear relay clicking when it stops halfway. sometimes it keeps on clicking while the blade slowly works its way down to the resting position
Go to a wreckers and ask if you can use a relay just to check it works. If it doesn't make a difference clean the motor. I'd say its one of the two.
Yeah, I know the seller's place, the one you posted on trademe. Hopefully it's just the relay, otherwise will have to take out the wiper motor this weekend
$20 for you ! its e34 should fit !
No.
Thanks, any pics of the ones you've got?
Edited by Tom325
Thanks, any pics of the ones you;ve got?
Tom e34 relays are totally different.
actually it does matt lol
Does it look like this?
Posted Image
Well at least you know what an e30s washer relay looks like now ;)
Guest Hondafit
rong !
Tried several relays but still didn't fix the problem. Guess it's time to take out the motor tomorrow :ph34r:
