ADEOSE
2007 BMW M3 Gintani Supercharged
2007 BMW M3 – Gintani Supercharged
6 Speed Manual
69000 kms
650 Hp
Reason for Sale : Just found out I am expecting another child - Need 4 doors.
FYI
Gintani stage 2: 7-7.5 psi
Brand new updated oil pumps and bottom end rebuild – This is part of adding the kit.
Vortech V3 Si Trim supercharger
Black Hard Anodized CnC Supercharger Bracket
supercharger discharge pipe with Tial blow off valve
Billet Aluminum CnC Machined Air to liquid integrated intake manifold (Available in custom colors)
Bosch water pump
Water lines AN fittings and Reservoir Tank
Front mount heat exchanger
Eight High Flow Fuel Injectors
Eight Rib Crank pulley
Eight Rib idler pulley/Rib tensioner pulley
Carbon fiber ram air tunnel
AFE Air Filter
Steel braided oil cooler line and fittings
Custom ECU Remapping
20†Alloys
Full aftermarket Exhaust
All work completed by C&M Performance Auckland NZ – With receipts.
https://skydrive.live.com/?cid=ee0820cd240f...AKNpyH2iYMVylrs
$76,000
Will trade on M5
Edited by ADEOSE
