M3_Power 636 Report post Posted August 14, 2013 (edited) I pulled this out of a faulty spare oval mirror that I fixed with a new glass - it has the usual bubbling in the middle - hasn't leaked, so technically you can just drain the liquid inside and run it as a non-dimming mirror given there's no staining by the looks. (Bubble only in the middle - the green you see on the right bottom is reflection of my phone) This is how you drain the liquid inside http://forums.bimmerforums.com/forum/showt...16#post16947716 I haven't drained this, but it is not hard to do and a cheap alternative to buying a new glass (or sending it away to have it repaired) $40 take it away. Edited August 14, 2013 by M3_Power Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted August 24, 2013 (edited) Now drained .... so no longer functions as an auto-dim mirror. Cleaned and put back together ready to use. Will do an exchange deal at $15. Edited August 24, 2013 by M3_Power Quote Share this post Link to post Share on other sites
