SimJen 0 Report post Posted August 14, 2013 So my 330 popped up an error and has gone into limp mode. P0339 which is the crank sensor, I've ordered a new one and will be fitting it tonight. My normal OBDII scanner will only reset standard fault codes, will not reset DME and adaptations. I've read that Limp mode requires a full DME Reset to get rid of, is there anyone in the Cambridge/Hams area other than Coombes Johnstone that has the proper BMW tool for this? Thanks Si Quote Share this post Link to post Share on other sites
