M3_Power 636 Report post Posted August 21, 2013 (edited) I purchased a bunch of used ones to see how they were put together and whether the aluminium part could be replicated and whether the corrosion could be repaired or polished back to original. Experimented with cutting out the corrosion and touching up with a layer of clear coat as the best solution in the end. These are the best used sets I had out of the lot - so I tidied them up as much as I can and polished them up. Not perfect, but reasonable. In used condition, so don't expect them to be new. You don't want to know what these are retail and if you've tried to import them from overseas trust me that they WILL be damaged when they arrive < - Ask me how I know!!! $200 take them away : ) NB. No damaged mounting clips all perfect : ) Edited August 21, 2013 by M3_Power Quote Share this post Link to post Share on other sites
