nzodea
large case 4.10 or 3.91 LSD for m3 evo
Hi after full diff or just crown and pinion to modify current diff.
for a race car so will be ramped etc.
Also after e36 m3 5 speed gear box to swap out the current 6 speed.
let me know what you have
Doc
Doc
I'll have some m3 5 speeds available in around 6 weeks. Trying to find that ratio is pretty difficult in the 210mm ratio you will need to try get one from another vehicle- e32 e38 e39 7 and 5 series etc. I have an M3 Evo diff that I was going to use for my project but if you do want to build up a diff as a bolt in unit then I could part with it. Otherwise change to medium case and finding diffs is alot easier.
Doc
HI
I have a large case diff for a E34. Want $550.00
Peter
Doc
could do you a large case 3.07 lsd for $450 if you could locate the other parts.
