Cab
E30 ABS Speed Sensor Replacement
Hi,
So my ABS light came on a few days ago and I had a gander and found my front passenger speed sensor was a bit rooted, the wire is pretty well exposed now so my guess is it's that. The light goes off once car has started and comes back on after a minute or so of driving so definitely a sensor issue.
In terms of replacing, anything special I need to know? Or simply unplug and replace? I only had a really quick look at it, do I need to go under the hood and follow the wire or does it unplug from under the wheel arch?
Cheers
Edited by Cab
