swanman
odometer on my e39 2001
Hi.
I know about the pixelation issue. However I cannot see my odometer read out at all.
After reading the instructions I have pressed the button on the dash and put the key in the 0 position but I cannot get anything at all.
I can see the read out below where it tells the time and the data which you can scroll with the button on the stalk on the left hand side.
The odometer info used to be there, buggered if I can find it now.
Any ideas? The WOF inspector has failed the car because of this and I think this should be a quick fix.
Cheers in advance
Fraser
It is probably still pixel failure. Originally our car had pixel failure of varying degrees right throughout the display.
Robinson Instrument Service in Auckland repair them
