Coffee&Doughnut
Strut brace
for the e30?
not as much as the front, but yes its good. seems more tied down and together. more noticeable with stiffer shocks/springs
meh screw getting all that, just go for the full cage if your after chassis rigidity :D
$90 strut bar, xxxX$ cage
cages are badass
Guest Andrew
teh win :mosh:
Yep E30,
I was beguining to think it might be a waste of money, 110 bucks delivered seems ok. Will get a front one eventually, dont know about a roll cage though, if I had the right car and the dough.....man Im just messen around at this stage.
where is the best place to get quality front and rear strut baces for a F/L e30? and about how much will they set me back?
Gus sez that this place on Cook street in Auckland city does JDM ones that can be made to fit... Otherwise you'd have to have one sent over - sparco does a cheapish one for 129US, otherwise you'd be going to aatuning.com turnermotorsport.com for something a lot more expensive..
