*bM**
Help with brakes on a E36
Hey guys,
Im after a brake upgrade on my E36 M3... my standard discs and pads are pretty worn and in need of a change. I want to get something that i can use every day on the street but will handle a bit of a trash on a track every now and then. What do you guys reakon i should go for ? I was thinking of a set of sloted front and rear DBA discs... not sure of the pads tho. Any thoughts?
Cheers Brendon.
+96 M3 Evo Floating Rotor's from BMW (~$250ea, could get them cheaper ex.USA as they are a common mod over there), and some good pads (Pagids, Hawks, Mintex, etc...) call Steve @ RaceBrakes.
Guest Andrew
Just got a full set of brakes from race brakes - DBA slotted with mintex pads + fluid. Was a bit slow - but they had to get them from aussie and stuff.
Would recommend them.
Cheers guys, ive orderd DBA sloted track spec discs front and rear. Ferodo DS2500 for the front pads and some metal king performance pads for the rear. then just standard brake sensors and Brembo performance brake fuild.
Ill let you know how they got ive got like a 10 day wait till they land from aussie.
Guest Andrew
See they tell you 10 days - its more like 3 weeks hah :D
Ah well, should've gone with the Euro Rotor's, much better product than the heavy 1pc DBA rotors, never mind.
