e30joe
E30 Coilovers/adjustable suspension
Wanting to get coilovers/adjustable suspension for my e30 318i!
Must fit 45mm struts!
Can swap my current suspension (h&r springs with bilstein shocks) with cash your way!
Cheers
Go on trademe and order the bc golds. Im pretty sure he has one set left in 45mm. Well he did the other day.
Also if its to hard to find 45mm adjustable just upgrade to 51mm.
itl make doing the welding and what not easier too as you wont have to take the fronts you have out till the new ones go in.
Also will allow you to go back to standard should you ever need to
Sent from my iPhone using Tapatalk
Bump
bump
bump
Anyone?
